Temp Display on Dash
Old Feb 22, 2009 | 12:09 AM
Capo Cam's Avatar
Default Temp Display on Dash
I think my temp sensor may have went out? The dash no longer displays the outside temperature. The digital clock and everything else works fine I just get two "- - F" on the temp display. Is there something else I should look for or do you think the sensor in the front end finally went out? Obviously this is not a major problem just a minor annoyance.
Old Feb 22, 2009 | 07:02 AM
On your car the sensors for the temp guage are connected inside the side view mirrors on the door.
When you swapped the doors did you use you window switches or the ones that cane with the door?
VolvoFred
Aug 27, 2010 09:09 AM
seanmathes
Mar 24, 2010 09:32 PM
nmt0m35
Apr 10, 2009 11:30 PM
Pretorien
Apr 12, 2008 07:49 AM
erocheleau
Oct 27, 2006 06:37 AM
