dash outside temprature display
Old Oct 20, 2006 | 11:30 PM
erocheleau's Avatar
Default dash outside temprature display
my dash temprature display how worked all along until i started my car one day. the display is "LO" degrees farenheight. it is stuck on the "lo" display. any ideas?
Old Oct 21, 2006 | 12:08 AM
m1964's Avatar
Default RE: dash outside temprature display
Check the sensor -left hand (driver's) side behind bumper cover -reach from inside the opening in the bumper.
Old Oct 22, 2006 | 01:58 PM
erocheleau's Avatar
where exactly is the sensor in relation to the radiator?? thanks
Old Oct 22, 2006 | 02:05 PM
Psaboic's Avatar
You could also try pulling the fuse for a few minutes to see if that resets it
Glenn
Old Oct 22, 2006 | 11:06 PM
Volgrrr's Avatar
I don't know what model you have but on my '95 T5 wagon you can see the outside temperature sensor if you look through the centre air dam and drop an imaginary perpendicular line from between the edge of the grill and the RH front light (i.e. facing the vehicle).
The temperature sensor is clipped into a holder and is easy to remove.
But have you checked for any thing that may be fouling or obstructing the sensor head (e.g. little bugs lodged in there, gravel, etc.)?
It maybe worth checking - I found a large blowfly jammed in my temperature sensor even though the cabin read-out was not affected.
Old Oct 24, 2006 | 08:10 PM
erocheleau's Avatar
i have a 95 850 glt sedan. i am still unable to locate any sensor in that area. any more information would be much apreciated.
Old Oct 25, 2006 | 11:59 PM
m1964's Avatar
the sensor may have come lose -lay on the ground and look up under / behind the driver's side bumper -sensor is black plastic piece. My was coming out of the holder often, it would hang there on its wires.
Old Oct 26, 2006 | 11:15 AM
Volgrrr's Avatar
The Haynes Service and Repair Manual shows a diagram (diag 11.8) of a Volvo sedan with the outside temperature sensor located under the front scuttle together with instructions how to access the sensor.
Reference:- Haynes manual, Chapter 3, page 7
M aybe your vehicle is one of these.
Hope this helps.
Old Oct 26, 2006 | 03:39 PM
billofdurham's Avatar
Unfortunately the diagram in Haynes is for the Climate Control sensors and not the sensor for the ambient temperature. That one should be where previous posts place it.
Old Oct 27, 2006 | 06:37 AM
Volgrrr's Avatar
Bill,
Why am I not surprised.
It's just another black mark against my diminishing confidence in the Haynes manual.
S60B5234T
Jul 7, 2011 07:50 AM
VolvoFred
Aug 27, 2010 09:09 AM
seanmathes
Mar 24, 2010 09:32 PM
Capo Cam
Feb 22, 2009 07:02 AM
Pretorien
Apr 12, 2008 07:49 AM
