Throttle body
Old Sep 12, 2005 | 03:36 PM
JPizano23's Avatar
Default Throttle body
Tech, I would like to clean the throttle bodyon my S80, there's no problems but I've read a lot of incidents where owners have problems due to build up. Can you guide me through the process? Also, thank you for the help on replacing my serpentine belt. With your help I've actually saved about 1500 in repairs.
Old Sep 12, 2005 | 08:48 PM
Default RE: Throttle body
I forget is it turbo or non-turbo?
Old Sep 15, 2005 | 03:08 PM
JPizano23's Avatar
Non turbo
Old Sep 15, 2005 | 09:53 PM
Buy a throttle body gasket first.
Then remove the hose going to the throttle body.Next unscrew the throttle body and remove.
You might have to remove the bracket on the back of the starter.It will be 2 10mm nuts and 1 12mm screw.That will allow the wiring to come out from the starter.
Then clean with Carb cleaner.
Old Sep 16, 2005 | 03:37 PM
JPizano23's Avatar
I'll do that this weekend, thanks tech
Old Sep 16, 2005 | 08:49 PM
No problem let me know how it goes!!
MFHull
Oct 9, 2014 09:01 AM
treestone27
Apr 29, 2014 07:40 AM
go2sharks
Jan 21, 2009 10:24 PM
proudmonkey
Jul 21, 2005 10:01 PM
wavewright
Apr 9, 2005 06:15 PM
