Throttle body angle at idle
Old Aug 7, 2013 | 01:37 PM
_val's Avatar
Default Throttle body angle at idle
Hello,
today I took off throttle body.
It's Magneti Mareli unit with mutiple numbers on it.
410CCZ55G
06W221203
8644347 <-- this looks like Volvo number
65CCFM-2
AH.0012381.E
What I wanted to ask is:
Is this normal that throttle is opened so much when "closed"?
Upper semicircle white line is light from other side... Approx 1mm wide.
I'm trying to deal with RPMs jumping around at idle. Not every time, but it sometimes it happens.
Throttle body looked clean.
Big intake hose below was damn dirty from outside. Inside clean to my eye.
Throttle body was installed new OEM before 6 years. Previous owner paid 900$ for it + installation.
Volvo S80 2000 T6 with 2.8twinT
Old Aug 7, 2013 | 11:38 PM
majorcode's Avatar
Hi, Yes it seems normal regarding opening and closing.
Plus there may be multiple reason
1. PCV Clogged
2. Need to clean Hoses
3. Need to clean MAF
4. Check Air Filter
5. Check Fuel Filter
6. Throttle body needs cleaning which seems you already done.
I got the same issue but when I done with all these check ups and cleaning...its done. Good Luck
MFHull
Oct 9, 2014 09:01 AM
treestone27
Apr 29, 2014 07:40 AM
And1one
Jul 15, 2012 05:12 PM
MarksS60
Nov 21, 2011 05:48 PM
markcaddell
Jan 8, 2011 09:56 PM
