Tons of problems that all happend overnight!
Old Nov 10, 2009 | 11:10 AM
doddj22's Avatar
Angry Tons of problems that all happend overnight!
I have a Volvo S80 2.4L. This morning it started to stall at red lights and stall at increased exceleration. Telling me to "Dive slowly service urgent", Emmision Service Required", "Transmission Service Required", and "Bulb position Failure".
I do have a small gas leak due to a cracked tank but, its not noticable unless in traffic or stopped for long periods of time. Replaced the transmission 3yrs ago. Reading about coils.. could that be the problem. Please help I cant afford this right now! I just moved into a new house! The car is a 99 with 170K I just need it to be reliable for 1 1/2 more years . Also replaced radiator, radiator hose, struts, axels, battery 3 times, spark plugs, and Im sure there is more that I cant remember right now.
Thank you kindly in advance!
Jessica
Old Nov 10, 2009 | 12:19 PM
imhereftw's Avatar
Probably not the best idea to be riding around with a cracked fuel tank.
Old Nov 10, 2009 | 01:06 PM
doddj22's Avatar
I know, I just dont have the funds to fix my POS at this time. I did go to Autozone to have the codes pulled and this is what they gave me.
P1330
P0442
Any ideas?
Old Nov 10, 2009 | 10:51 PM
fs's Avatar
fs
P1330
P0442
Any ideas?
P1330 CVVT solenoid----Search the forums about this one
P0442 EVAP Emission Control System Leak (Small)----Gas tank leak you mentioned Ima thinking.
Bulb position Failure----more than likely one of the tail light bulbs is either burnt out..or just has a bad/loose connection.
For the other ones try searching for something bout the ABS module on here I think...
Old Nov 10, 2009 | 11:34 PM
blackbrick's Avatar
I found this on P1330
misterruby
Dec 14, 2018 09:48 AM
junkyardpower
May 27, 2013 12:48 PM
davisrf
Apr 8, 2011 09:52 AM
egm8599
Aug 25, 2010 05:50 PM
mbsjshad
Nov 6, 2009 03:56 PM
