transmission fluid
Old Apr 8, 2010 | 10:03 AM
Stacy's Avatar
Default transmission fluid
Hello all,
First off I just purchased this car.... its a 2000 s80 t6, when I bought it all the fluids were at the proper capacity now 3 weeks later the tranny fluid is low. so I went to napa and they told me it took dextron III. So I added a couple quarts to the correct level and now the transmission feels like it shudders and slips a little,and the check engine light blinks while it shudders ( The check eng light just came on last week and the code was for the valve reset solenoid, I purchased it but it has not arrived yet). Did I add the wrong fluid? or could it have to do with the solenoid?
Old Apr 8, 2010 | 11:39 AM
JRMac1953's Avatar
Default Trannie Slip
Originally Posted by Stacy
Hello all,
First the mechanic was correct. Volvo uses a Dexron III fluid. You may need to add some Slip Lock to it. You may want to have your trannie flushed and start with new fluid instead of mixing. I know Amsoil makes a Synthetic Trannie fluid (ATF) that meets the spec and does not require slip lock. Depending on the Trannie AW 55 or AW 50 you could also use the Torque Drive Trans fluid (ATD). Let me know if I can help. Just so you know I am an Amsoil Dealer.
Old Apr 8, 2010 | 12:01 PM
Stacy's Avatar
This is the first volvo I have ever owned, how do I tell which transmission I have the aw 50 or 55? and what is slip lock I have never heard of it.
Old Apr 9, 2010 | 11:08 AM
JRMac1953's Avatar
Your mechanic should be able to tell you off the VIN number which Trannie you have. Slip lock is just an additive to help make the trannie fluid a little stickier. . I suggest whether you go regular fluid or synthetic that you have all the fluid changed so you know at least that you ahve good fluid in the car.
Old Apr 9, 2010 | 11:46 AM
vegasjetskier's Avatar
Stacy, your car has a GM 4T65E-GT transmission (made by General Motors). It does use the Dexron III fluid (or the Dexron VI replacement for Dexron III). You can drop the pan on this transmission and replace the fluid filter. That might help. Here is writeup: http://www.matthewsvolvosite.com/for...p?f=11&t=20278
Old Apr 9, 2010 | 01:09 PM
Stacy's Avatar
thanks for the info
Old Apr 9, 2010 | 01:46 PM
nicolaselias's Avatar
If interested, you can also reference my writeup for this car
https://volvoforums.com/forum/showth...t=transmission
It should cover mostly everything that I did...
I'd recommend dropping the pan and changing the filter, also, installing an in-line filter as is mentioned in my writeup
AustinPower
Nov 11, 2008 07:43 AM
flyingo
Apr 27, 2005 07:19 PM
94volvo850
Feb 18, 2005 06:49 PM
