Transmission Oil
Old Sep 17, 2013 | 04:39 PM
majorcode's Avatar
Default Transmission Oil
Hi, I Changed my transmission oil 20,000 KM ago, and putted Castrol with lucus oil. I rarely feels jerk while engine/transmission hot...I want to change the oil now...but as per my last experience when I dropped the pan and lost the transmission............I do not want to change oil completely.
my question is can I top up or change 3 or 4 liters with Merc or Volvo same specified oil ?
Old Oct 26, 2013 | 01:48 PM
akabond's Avatar
why change it again. i would say just a drain and fill would be fine. i havent done on mine but will do it soon
Old Oct 29, 2013 | 10:47 AM
majorcode's Avatar
just for the sake of having good oil like Merc or Volvo..because I am not happy with Castrol.
Old Oct 29, 2013 | 11:24 AM
akabond's Avatar
what do you mean you are not happy with Castrol.
Old Oct 31, 2013 | 01:28 AM
majorcode's Avatar
Yes, because they get over heated early and I believe for our weather there should be only Merc or Volvo Oil. I have seen here 65 C at one time...... so you guess.
Old Oct 31, 2013 | 05:49 PM
difflock54's Avatar
Is your vehicle fitted with the GM transmission or the AW alternative?
The type of ATF fluid requred is different for each.
The AW (Aisin Warner's) use 3309 spec fluid.
see attached link re GM transmissions. class action settleement. for your info'
https://volvoforums.com/forum/volvo-...ion-oil-73659/
http://www.matthewsvolvosite.com/avo...on-issues.html
Old Nov 1, 2013 | 10:10 AM
majorcode's Avatar
It is GM Transmission and used last time as per specs. Dex III.
Old Nov 1, 2013 | 08:11 PM
difflock54's Avatar
Just do a simple and gentle 'drain and fill' procedure.
Drain out approx 3.5 quarts via plug and replace via dipstick tube with funnel same amount of fresh ATF. DEX III
Run it for about a week or so and then repeat procedure again. Should look clean like new.
If it looks a good clean color after the first cycle after some running you may be able to leave the 2nd cycle especially as you have only done 20k on the existing.
A third cycle should only be needed if the fluid is still appearing significantly discoloured and is most unlikely.
Old Nov 3, 2013 | 12:15 AM
majorcode's Avatar
difflock, I agree with your idea. I did this last time and it works good.
Since some seniors are here in this post, will appreciate if you guys help me with this post.
https://volvoforums.com/forum/volvo-...24/#post370666
nuclearseal
Aug 17, 2022 01:48 PM
mason3325
Dec 22, 2021 12:51 PM
jeffrisley
Jun 14, 2015 01:48 PM
endneu913
Nov 21, 2010 10:53 AM
