vacuum leak
Old Jan 24, 2010 | 09:49 PM
Billc's Avatar
Default vacuum leak
Hi, gang..have a 2000 S80 with 231,000 miles....started to drive yesterday and immediately noticed low speed stuttering, finally stalling a ton of times...restarted just fine, but problem repeated often but ..took to big Sears place with good rep, guy called me today frustrated: said obdII said a major vacuum leak, but they couldn't find it-did smoke test, etc., but couldn't go any further. Any thoughts? Love this car and want to hit 300,000 but can't spend a fortune on it. Any help or thoughts would be greatly appreciated. Thanks,
Old Feb 6, 2010 | 07:17 PM
nblair80's Avatar
All right I had something similar to this when I changed out my coil packs. It was a loss Vacuum leak caused my the main vacuum line that connected to my turbo intake. It is the one just behind the radiator and runs in front of the engine. I had just forgot to connect it and it was causing the turbo blow offs to not open and let out the pressure. I know I was the dumb one for the day. Try and see if you are throwing any codes. Might help you trouble shoot the problem. Good luck man!!
robnov
Oct 6, 2007 05:03 PM
nick54
Dec 21, 2006 07:21 AM
pc142
Oct 17, 2006 03:37 PM
speedwagon
May 26, 2006 12:09 PM
hordezla
Apr 14, 2006 08:59 PM
