vent box
is it possible to remove the vent box without removing the alternator and AC compressor? can i just remove the top of the box for cleaning? i have oil comming from the vent box and into the boost system what would cause that? is there a filter or something that gets clogged? thanks
i tried to make a tool to get the bolt out but it didnt work out so i removed the the alternator, AC compressor (just unbolted) and removed the power steering pump and housing completely.. this sux i am finaly done with the "tear down" and basicaly all thats left is the block... i have a list of parts to order now to get back up and running.. I STILL NEED A WAY TO CLEAN INTERCOOLER is it possible to clean without removing from the sandwich? i have taken apart enough.. lol
id imagine that it would have a plug in it anyway? maybe not i havnt seen it yet... if its realy small then probly not too much air gets through it anyways and it wouldnt matter.. i think they SHOULD have a hole in there that you can drain so that you can flush it out without having to remove the hole thing and either acid bath it or flush it..
