vibrating/shaking problem
Old Jan 7, 2006 | 04:34 AM
ghostriderT6's Avatar
Default vibrating/shaking problem
2000 s80 T6. when driving at highway speeds the car tends to vibrate and shake...as if the wheels aren't aligned or something. I had this problem before and it mostly went away when i had the wheels aligned but now it is back in full force. The tires are new. What possible things could be causing this problem? do i really need to have the wheels realigned every couple months? or could this be a problem related to the suspension...a bent sway bar or something?
Old Jan 7, 2006 | 09:07 PM
Default RE: vibrating/shaking problem
One of the tires could be out of round. One could also have lost a wheel weight.
Old Jan 13, 2006 | 02:48 PM
Coastal's Avatar
Agree with Tech, sounds like a tire isn't balanced. Have them balance the tires again.
Old May 4, 2006 | 04:15 PM
jerryman's Avatar
I had the same problem and just got it fixed. It was the rubber cusions on the front springs. They had worn out, thus causing a vibration. While replacing those, found out that the shaft and cv joint was also bad. No vibs now.
dece207
Feb 18, 2024 12:31 PM
Volvo_n00b
Feb 26, 2011 01:08 PM
kozhockey4
Oct 13, 2005 07:22 PM
r2u
Aug 28, 2005 01:44 PM
danielribo
Apr 15, 2005 10:41 AM
