Volvo s80 i6
Old Nov 2, 2016 | 11:06 PM
  #21
Petar17's Avatar
It's pushing air out. Blowing through dipstick...
Old Nov 2, 2016 | 11:32 PM
  #22
thommykent's Avatar
Clogged up PCV system. Try removing the oil fill cap. I think the noise will go away also.
Old Nov 2, 2016 | 11:36 PM
  #23
Petar17's Avatar
Yes. It's the same thing when i move oil cap. I already bought the part. Just I don't know can I replace it by myself or i need mechanic... I am not realy good, but i can take of the parts and put it back if i have some pictures or instruction...
Old Nov 2, 2016 | 11:53 PM
  #24
thommykent's Avatar
Here`s a couple videos for the 5 Cylinder basically the same as the 6 cylinder. It`s fair amount of work.
Old Nov 2, 2016 | 11:54 PM
  #25
Petar17's Avatar
Thank you very much
Old Nov 3, 2016 | 05:13 AM
  #26
thommykent's Avatar
Same noise yours makes.
Old Nov 3, 2016 | 07:41 PM
  #27
Petar17's Avatar
Originally Posted by thommykent
Exactly the same thing. Same noise same symptoms, blowing air when I put dipstick out. And I can't believe, all "mechanics" I asked, I described the simhtoms, everybody telling me that's engine blown out . Engine works perfectly, has 143000 miles on it.
Old Nov 3, 2016 | 08:41 PM
  #28
thommykent's Avatar
Good luck if you try to do that yourself. Getting the intake manifold back on correctly is imperative and use a new gasket. Is their an independent Volvo shop near? I would think they would do it for around $500. If you do it yourself buy OEM Volvo hoses and the oil separator assembly. FCPgroton is good for parts. Don`t buy their cheap crap. Or anything labeled Pro Parts Sweden
Old Nov 3, 2016 | 09:08 PM
  #29
Petar17's Avatar
I already spoke with vilvo mechanic, only original parts and hoses and gasket with labor 400$. That is a good deal...
Old Nov 4, 2016 | 05:52 PM
  #30
Petar17's Avatar
Hey guys. Do anybody know what this is? I turned of the vehicle and this things worked like 10 more minutes and then they shut off. Car wasn't running and key wasn't on, I took key out of the car. I don't know what this part is and is suppose to work like that when the engine is off???? Thanks guys.
Old Nov 6, 2016 | 01:15 AM
  #31
Petar17's Avatar
[QUOTE=Petar17;439916]Hey guys. Do anybody know what this is? I turned of the vehicle and this things worked like 10 more minutes and then they shut off. Car wasn't running and key wasn't on, I took key out of the car. I don't know what this part is and is suppose to work like that when the engine is off???? Thanks guys.
[/QUOTE
Izgleda niko ne zna
Old Nov 6, 2016 | 02:35 PM
  #32
e.mence440's Avatar
Banned
that noise is the fan for the ECM , sometimes it will stay on for a few minutes after you turn off the engine , it's used to keep the ECM cool....
Old Nov 6, 2016 | 05:19 PM
  #33
Petar17's Avatar
Thank you
darkostoj
Aug 1, 2018 08:27 AM
rmwjr
Mar 12, 2008 07:31 AM
scubahottie
Jan 7, 2008 04:25 PM
sk36
Aug 9, 2007 09:59 PM
robretpd
Feb 21, 2006 12:02 PM
