Window Frame Trim
Old Jul 7, 2009 | 02:47 PM
skooter66's Avatar
Default Window Frame Trim
There is a black film of some sort that has been applied around the four side window frames on my S80. When I bought the car, the dealer told me it was a 3M product. That film, whatever it is, is now starting to wrinkle and warp and doesn't look that great anymore. It looks easy to apply/replace if I could figure out what that film is and where I can get it. Any one out there know what I am talking about and have any suggestions? Many thanks.
Old Jul 7, 2009 | 08:22 PM
spunkymonky's Avatar
It is a factory applied decal. Not sure how hard it is to redo but you can buy it here. Let us know if you change it how hard it was. I know many people ask about it.
http://www.trademotion.com/partlocat...layCatalogid=0
Old Jul 7, 2009 | 09:27 PM
beefheart's Avatar
I am master certified in collision repair, the high price of these decals, and if someone is not familar with how to apply them, can turn into a major regret, my advice is this, take a hair dryer and move the dryer back and forth close to the decal, dont hold it long in one area, keep pulling the decal off the frame, then find a paint friendly adhesive remover, 3m has one that I use, after the decal is gone, and the adhesive removed, mask off the frame area you want to color, use a light scuff pad to scuff the area, preclean and use a black satin spray can to color the area, light coats are best applyed while useing the hair dryer to speed up the paint cureing time, take your time and I think you will be pleased with the results, also you can buy a good bottle of wine with with the money you saved by not getting hosed by buying the decals. best regards, beefheart
Old Jul 8, 2009 | 06:56 AM
skooter66's Avatar
Thanks for link for the decals, but what is on there now is not the stock decals. One of the original decals was in bad shape when I got the car and I watched one of the lot prep guys apply this unknown 3M material that looked great about 3 years ago but has weathered badly in the last 12 months...looks a lot like UV damage.
I may give the paint option a try. Sounds time consuming, but I am thinking the results may last a little longer and may look better than the original decal.
Old Sep 25, 2009 | 03:20 PM
brobabs80's Avatar
Took me forever to find this thread. I have the exact same problem. I had the decals replaced once under the 50k warranty. 15k miles later, they look worse than when I had them replaced.
Beefheart - Any specific paint recommended for the pain option? I am leaning that direction as a do it myself option. I am a former coatings contractor and have good paint skills. It seems the weather strip removal and the masking will be the hardest part.
Old Sep 25, 2009 | 06:50 PM
beefheart's Avatar
ask the paint/parts place for a spray can of 'black satin trim", I have used wurth brand with great results, just take your time and dont get in a hurry, try to do the job in a shop or garage, use lots of paper and masking tape, I think you will be happy with the results, good luck, beefheart
Old Jul 16, 2010 | 04:33 PM
medford mark's Avatar
Default I'm going to dp the paint option as well I need new trim at bace of side windows
I'm going to use a high temp paint as it gets in the triple didgets here. Stove Brite web site has a great color selection. Any one know a resonably priced sorce for the cracked rubber strips at the base of the side windows? I have a 2000 s80
hovonogila
May 16, 2019 02:28 AM
stww1fa
Sep 23, 2008 10:16 PM
jmc00v70
May 25, 2006 06:53 PM
moet32
Sep 23, 2005 02:34 AM
drfrankenstein
Mar 25, 2005 09:57 AM
