1999 S90 Security System
Greetings,
We purchased the above car at the end of January, and while we're pleased with it so far, the stock security system is proving to be too cumbersome for our tastes. This S90 came from the dealer with 2 sets of keys, but only one alarm remote, and we aren't entirely pleased with the automatic nature of the alarm system. I shouldn't have to 'beep beep' the silly alarm system after pumping gas or picking up a pizza. Has anyone ever disabled their own alarm system? Could it be as simple as removing the fuse in the alarm slot?
Thanks for any help you can provide.
Chris
Chris
RE: 1999 S90 Security System
Howdy. An obvious newbie here with my hand out.
We have the 1998 model S90. The alarm system has been acting up lately. After opening the car with the remote, every now and then, it either merely won't turn over, or the alarm sounds as well. Only the actual key saved us.
The batteries check at slightly over 3v, and besides, the remote has never made the low battery beep. Could they still be low? Would low batteries cause these symptoms?
That could explain an "electric motor-like" sound sometimes after the car is shut off. This has only been reported to me by the wife, and this sound also stops as the door is opened.
One thing that I can't personally verify, she says the sound appears to emanate from the dash area. These motors are in each door though, I assume.
I will have her really try to nail down the location next time.
Security System problem possible update
After a failed attempt to recreate and solve the intermittent problem, a local service shop suggested a bad key, which is the easiest fix as well.
Otherwise, a bad antenna ring or, as mentioned here, door lock.
We have switched to a spare key and are anxiously waiting for something (or hopefully nothing) to happen again.
