B4204T31 Oil drain plug torque specs
Old Aug 10, 2022 | 01:25 PM
FrancoisC75's Avatar
Default B4204T31 Oil drain plug torque specs
Good morning/afternoon all!
I'm struggling like hell to find proper drain plug torque specs for me 2018 T4 V90.
Engine code: B4204T31
I see there are some differences between volvo engines:
Volvo S60 / V60 Torque Specs (2010 on)
I didn't find it using the forum search.
Do you have a general document for this engine/car?
Thank you very much!
Regards,
Francois
Old Aug 10, 2022 | 04:25 PM
Not sure if there's a formal document with a spec but I've always used 20-25 ft-lbs as a guide for the oil drain plug. to convert ft-lbs to NMs, divide by .74. Most people over-torque the plug... Also I assume your year still uses a crush washer (again most people don't bother to replace, which is why they over-torque)
Old Aug 11, 2022 | 02:21 AM
No aluminum washer that I change everytime ;-).
I'm quite sure there is a torque spec. I believe they (Volvo) should communicate on this...
As you can see in my previous link, depending on the engine, the torque value is different.
I'm just trying to ensure I'm doing it perfectly.
Else, I'll just tighten it by hand like I used to do. But would prefer the "precise" way.
Thank you!
850R4Ever
Jan 15, 2014 02:53 PM
chrispy960
Jan 15, 2013 02:57 PM
dbm_nj
Apr 5, 2009 11:41 AM
LeChasseur
Jan 9, 2009 01:33 PM
tobo57
Jan 9, 2008 07:10 PM
