Several electronic issues on my V90
Old Aug 30, 2022 | 02:43 AM
jlgarnier's Avatar
Default Several electronic issues on my V90
Hi Community,
I've recently bought a used V90 T8 R-Design from Germany (first use June 2020) and I've noticed several issues which I link to electronic systems:
  • Untimely blocking of the sunroof: after activating the control, the blackout shutter moves back 10 cm then stops. The sunroof does not move.
  • Refusal to lock the trunk: key in the pocket, the car beeps 3 times when I try to lock the car and the trunk simultaneously. The command may work after several tries. The simple lock of the trunk works.
  • Incorrect mirror settings: after selecting a profile, the exterior mirrors do not find the settings defined for the chosen profile.
  • Rear-left window: the window goes down on a single push of the button, but only goes up if the button is activated continuously. All other windows work properly.
Did anyone encounter such issues and what did you do to fix them (without going back to the garage &#128521?
Thanks in advance for any help!
Old Aug 30, 2022 | 07:20 AM
Pioneer4x4's Avatar
Are you sure you aren't putting the sunroof in the vent position? The control moves 2 different ways.
Old Aug 30, 2022 | 08:10 AM
jlgarnier's Avatar
Yes, I'm sure. I'm starting from a full-close position, make a long-push action on the button: it sometimes works as intended (shutter fully rolls back, then the sunroof open half / first position, while a second action fully opens the sunroof) and sometimes just fails, so it's definitely not a normal behavior...
Old Aug 30, 2022 | 08:35 AM
Pioneer4x4's Avatar
OK, worth a shot.
kasey0505
Mar 3, 2025 04:28 AM
1999myC70
Sep 26, 2018 09:37 PM
Anieto
Apr 9, 2013 10:52 AM
stevied
Jul 2, 2007 03:08 PM
luckytweaker
Aug 30, 2006 08:59 PM
