Cruise Control Vac line
Old Jan 29, 2014 | 09:17 AM
Konrad101's Avatar
Default Cruise Control Vac line
Just replaced the cruise control vac diaphragm unit on our V90 and found that the other end of the vac line is not connected to anything. There was work done on this car and I can not find where this line might connect. I "think" there's a spot where some straight rubber tubing was installed that looks like it might be where this line "T"s in but I'm not sure. Not been able to find any info on line. Am hoping that someone here can give pretty clear directions to where this line goes. A picture would be great.
Old Feb 7, 2014 | 08:14 AM
vxracer's Avatar
Give me a few days to buy this s90 and ill grab pics. If its idling, the suspected correct nipple should be pulling vacuum. If that's the only loose hose, the should be only one open nipple-in theory as long everything else is installed correctly. Take a BIC lighter with no flame, shoot butane at the suspect nipple, or Carb cleaner. If motor stumbles, you found it.
Old Feb 14, 2014 | 10:56 AM
vxracer's Avatar
Did you solve this?
dawagner93
Apr 28, 2015 07:21 AM
rspi
Mar 7, 2010 06:13 PM
JetTech
Jan 25, 2007 09:45 PM
ENDEE666
Nov 23, 2006 10:10 PM
jfikentscher
May 31, 2006 09:58 PM
