Fog lamp blowing fuses
Old Apr 15, 2015 | 08:15 PM
mrbillcollecta's Avatar
Default Fog lamp blowing fuses
Swapped out fog lamp bulbs. 55 watts on a 25amp fuse. It worked all of 5 minutes now it's blowing fuses. Any suggestions?
Old Apr 18, 2015 | 11:06 AM
VDonkey's Avatar
I'm pretty sure 55 watts is the usual power of these lamps.
I would inspect the lamp bulb mounting area and connectors for corrosion. A ground short would blow fuse immediately.
Also be sure the 'hot' wire inside the lamp housing did not have its insulation come off and touch the ground!
Old Apr 19, 2015 | 08:22 AM
Good idea! I think I remember kinda stuffing the wires back in there. They May not be sitting right, huh?
Old Apr 19, 2015 | 01:41 PM
VDonkey's Avatar
Yea, also if connectors get dirty they will heat up and increase the current draw.
Old Apr 20, 2015 | 06:13 AM
Any advice on what to use in cleaning them?
Old Apr 23, 2015 | 01:20 AM
VDonkey's Avatar
I like using a pencil eraser or fine grit sandpaper like 800. Sometimes chemicals like 'brasso' will work.
Old Apr 30, 2015 | 08:05 PM
Looks like wires touching was the culprit. You can see the burn marks the wire @ 12 o'clock . @vdonkey thanks for the for advice.
briang232000
Oct 16, 2009 10:59 AM
Capo Cam
Mar 13, 2009 08:20 PM
vegedge
May 31, 2007 10:46 AM
liberty
Jul 19, 2006 08:44 PM
