Map data could not be read
Old Mar 20, 2023 | 02:31 PM
sapundjiski's Avatar
Default Map data could not be read
Dears,
I am trying to update the maps on my S90 2017 model, but its not possible. As a first option I try to update online directly from the car, but due to large file the system is requiring the update to be done via USB. I have downloaded the map from volvocars.com support through the "Sensus_Update_SPA_South_Eastern_Europe.exe". I have done everything correctly: Format 8GB USB into FAT32 File system, download the maps directly to USB in the root folder, and on the end I have verified the download. ALL was correct. When I am inserting the USB drive into the car on the central display is popping out message "Map data could not be read. Check USB and try again". I have try the same procedure with another larger 64GB USB, and the outcome was same.
Anyone to have idea how to solve this problem?
Old Apr 20, 2024 | 07:47 AM
Luking's Avatar
Originally Posted by sapundjiski
Dears,
Hello, did you solve this problem with maps? Thank you 🙏
Old Apr 22, 2024 | 10:33 AM
Yes, I did solve it! I found where was the problem.... since the update of the Volvo system, the only disk type supported (USB Partitioning) is MBR, GPT is not supported anymore. Not only for Maps, for every file types (music, video...). If you want to upload maps with USB, firstly make sure that the USB partitioning is MBR
Pretorien
Aug 7, 2023 06:57 AM
MyXC40
Volvo XC40
Nov 22, 2022 10:13 AM
crcarson
Jan 26, 2020 03:14 PM
Nancy N. Palmquist
Aug 13, 2019 12:27 PM
Pretorien
Jan 6, 2019 05:26 PM
