S90 Thermostat/Temp Sensor
Old Oct 30, 2017 | 11:00 AM
msmcpa's Avatar
Default S90 Thermostat/Temp Sensor
Hi, my '98 S90 has an 123ECT code that, from what I can tell, is a bad temp sensor with the recommendtion to replace the thermostat at the same time. Try as I might, I cannot find assistance on this for an S90 and none of the help for other models has a layout that looks like mine. Could anyone point me to assistance? Thanks in advance.
Old Oct 30, 2017 | 10:05 PM
follow the upper radiator hose to the top of the block - it should connect to a roundish cap - the thermostat is under that. If you remove the cap ( with hose attached) you should see the temp sensor screwed into the housing directly below.
Old Oct 31, 2017 | 05:40 AM
msmcpa's Avatar
Excellent, thanks so much!
Aryding
Dec 4, 2010 03:22 PM
bgeacook
Aug 13, 2009 12:43 PM
nvs40
Dec 30, 2006 12:14 AM
dcox612
Apr 23, 2006 01:08 PM
