step by step?
How would i go aboutreplacing thewindow washing fluid sensor? its prolly really easy but it sounds like something that a person like me could mess up.. Ive replaced my own radiator and helped rebuild the head in my 98 S90.. but how to do a window washing fluid sensor, is beyond me...Hahahaha
Thanks
Thanks
I belive it's under the airbox, right? So disconnect the airbox, then sort of wiggle it out, it's pushed into some little rubber grommets. I seem to remember two bolts, but I could be wrong - either way, the airbox is pretty easy/self-explanatory to remove.
With the airbox out of the way, the sensor is held in with a screwed on plastic collar right in the top of the reservoir. Undo the connector on the wire, unscrew the collar, pull the float/sensor straight up and put the new on in.
I got one from a junkyard.
Nicole Lolytte Brown
Dec 4, 2012 10:00 AM
