Unable to launch map update
Hi all!
I'm desperately trying to trigger a map update on my 2020 V90: downloaded the map using the Sensus_Update_SPA_France.exe tool to a FAT32 USB stick (tried also exFAT formatting), plugged it into the appropriate USB port and nothing happens. I already processed some updates months ago using the same procedure, so I expected everything to go smooth this time... I just can't understand what's wrong this time.
Any clue?
Thanks in advance for any help!
Any clue?
My suggestion would be to download to another USB and try again. You didn't mention what is actually going on, so my assumption is that you car isn't even reading the USB your using. Even if it is reading the USB, but the car isn't uploading properly, I'd still suggest trying this with another USB before going further to de-bug.
Hi @maggs ,
Thanks for your quick answer! Actually, this is the same key I already used for previous upgrades (and the car can read music from the stick), but you guessed right: I picked up another USB in my box and the map upgrade launched as expected! IT magics... 😁
Problem solved, thanks! How can I switch the status of this post?
