2000 V40 1.9t codes
Old May 10, 2015 | 04:46 PM
ehames005's Avatar
Default 2000 V40 1.9t codes
I just bought a 2000 V40 1.9t with the dreaded 0014 and 0015 codes and a cylinder 4 misfire. I have read a lot of the threads with these code issues and have done what was recommended, sea foamed the engine and replaced the oil with mobil 1 0w40 oil. The code still persists, also along with that while driving and accelerating hard when it hits 4000 rpm it just falls on its face and the "check engine" light starts to blink. When driving with out accelerating hard it drives just fine. Any pointers would be helpful.
Old May 10, 2015 | 08:28 PM
Take a look on the S40 board - there's a few detailed posts discussing the issues with the VVT that can cause the 14/15 codes. The problem is that the VVT can't control the exhaust cam timing so the position sensor throws a code and with the valve timing a bit off, you'll feel some loss of performance at some points in the RPM range. Use the search feature to search on "P0014" or "P0015" in the S40 board :=)
Old May 10, 2015 | 09:15 PM
ehames005's Avatar
Thanks for the info!!!
ddrewyor
Jan 8, 2012 03:36 PM
Garon
Apr 22, 2009 02:57 PM
gabyman97596
May 14, 2007 09:52 PM
shpeedy
Sep 26, 2006 08:08 PM
cranky
Aug 5, 2005 09:46 PM
