2000 Volvo v40 tailgate light problem
Old Dec 24, 2015 | 05:45 PM
JohnRSchutt@gmail.com's Avatar
Default 2000 Volvo v40 tailgate light problem
Hello,
My daughter has a 2000 Volvo V40. the running lights and the brake lights on the liftgate/tailgate don't work. However, the brake lights do work. The rear quarterpanel lights do work as they should. So, here's what I've checked so far:
the bulbs are fine, the fuses are fine, the wires that run from body to tailgate are not broken. I have no voltage to the light sockets.
Help! Please.
John
Old Dec 26, 2015 | 12:07 PM
you can grab the wiring diagram from volvowiringdiagrams.com to look for common junction points but I'd suspect the wires in the harness at the hinge may be at fault. BTW did you check both fuse boxes - the one under the hood and under the dash by the hood release?
Old Dec 27, 2015 | 04:30 PM
Hello,
Yes. I did check all of the fuses both under the hood and to the left of the driver's leg. I also pulled the rubber grommet/protector that cove the wires from the body to the station wagon rear lift gate. They were all in good condition.
Thanks for the help!
oskare100
Oct 17, 2021 11:54 AM
Scott A
Feb 14, 2015 09:21 AM
iambowie
Oct 21, 2012 07:27 PM
ddrewyor
Jan 8, 2012 03:36 PM
Garon
Apr 22, 2009 02:57 PM
