92 740 problem!!
Old Oct 24, 2015 | 12:42 PM
lastone1's Avatar
Default 92 740 problem!!
Hi guys n gals, I'm new here but hope you could point me in a right direction. My 1992 740 started stalling while driving and BARELY made it to my driveway and now wont start. I checked the scrader valve and the gas pump is working and I replaced the gas pump relay and still it wont start! I'm lost now on what to do because I cant afford a mechanic and the car is nice (135,000 miles) so any suggs. will be greatly appreciated! Thanks in advance..Also if anyone wants to troubleshoot you can contact me at 'usernamedchris@gmail.com' Thanks. Oh and also a new fuel filter as well.
Old Oct 27, 2015 | 09:31 AM
lastone1's Avatar
Anyone ever have this problem? It still wont start and I can hear the fuel pump hum and It has spark (checked the plug wire) so perhaps a distributor cap issue? I would appreciate any input!
Old Oct 31, 2015 | 12:12 AM
you need to read up on how to triage a no start or stalls while driving condition.
Volvo 740, 760 & 780 service and repair manual
If you went to the schraeder valve and have fuel pressure, then the next test is for spark... Pull a plug wire and use a spare plug - ground it and crank. you should see a nice blue/white spark. If you have spark and can hear it "almost" start, then you have to check into the throttle/mixture control mechanisms - start by inspecting hoses/tubing etc. Are the boots in good shape? Have you inspected the intake parts like the MAF? is the intake clean or dirty? oily? When was the last time the car got a tune up? plugs/wires/cap/rotor?
volvoQ's
Sep 26, 2010 01:45 AM
TheVolvho
Sep 15, 2010 04:26 AM
roamer
Jan 16, 2010 06:34 AM
lwrdr2
Jan 19, 2009 04:36 AM
TedH
Mar 20, 2006 08:32 PM
