V40 coolant problem and clicking noise
Old Nov 5, 2015 | 04:17 PM
-Jensen's Avatar
Default V40 coolant problem and clicking noise
My volvo v40 2002 is for some reason losing coolant fast, 100km and the whole coolant tank is emty. I preasure tested the system and the pressure didnt drop. My oil is good colour. And when I have it running for about 3-5min the temp guage shows that its overheathing however when i check the coolant it full, then I start the engine again and it goes to the working temperature it was before it overheated.
Summary: It overheats alot and uses alot of coolant, system holds preasure, and oil is good colour.
There is also a wierd clicking and banging noise coming from the engine, this noise came afther I instaled a new alternator. Cant figure out where in the engine room the noise comes from.
Enny help will be greatly appreciated.
Old Nov 5, 2015 | 09:07 PM
if there's no visible exterior leaking then there's two choices - 1) check the heater core ie feel around the floor by the pedals and passenger footwell etc. If you smell a sweet aroma when starting off that's a clue 2) its going into the engine - cracked cylinder head or head gasket. The fact you are seeing odd temp readings suggest either a head problem or a thermostat/temp sensor.
Old Nov 6, 2015 | 05:43 PM
-Jensen's Avatar
Thanks for the reply, I going to change the temp sensor and see if that fixes the problem.
Today I noticed a long line of coolant on the ground when i drove in 1gear. So I opened the hood and It looks like the coolant came out of the coolant tank.
Gardenhands
Jun 20, 2012 12:20 PM
iceracer46
Nov 8, 2011 09:32 PM
Chebucto
Apr 18, 2009 10:13 PM
kirks_volvo
Nov 17, 2008 07:32 PM
amikuk
Mar 12, 2008 01:04 PM
