brake hose corrosion v40 t4
would also like to add that replacing the brake hose's on this model after 100,000 km a must as corrosion occurs,the brake hose fail's and your left with no brake's as happened to me,most problems occur on v40 t4 2003 due to corrosion of rubber eliments i.e. ball-joints ,ignition coil,engine mounts,internal heater.
