CLUNKING LIGHT THUMP COMING FROM FRONT WEN PULLING AWAY
Old Sep 29, 2007 | 09:31 AM
markjenross's Avatar
Default CLUNKING LIGHT THUMP COMING FROM FRONT WEN PULLING AWAY
hi
i am seem to get a light clunking noise when pulling away from junctions or slowly and not all time but more rather than less.
can some 1 please help
this noise seems to be from engine bay area and is driving me mad
please enlighten me
Old Nov 9, 2007 | 10:20 PM
mncx's Avatar
Default RE: CLUNKING LIGHT THUMP COMING FROM FRONT WEN PULLING AWAY
does it happens when u slow the car down?? if it does check and see if lug nuts are tight on all wheels.. the wheels love to falls of on thoes car if excessive corrision build up between hub and wheels..
Old Nov 10, 2007 | 05:41 PM
happens wen pulling away from junctions and maybe wen change to second gear is noticable
Old Nov 15, 2007 | 03:33 AM
georgehifi's Avatar
Mine was doing this also, all engine mounts were fine, then I saw it, there is a stiffening barfrom one side of the chassis to the other, just behind the motor,this is firmly bolted to the chassis at 2 points left and right of the car. Mine must have been hit by something and bent it upwards slightly so the middle of the bar now touched the body causing the noise you mentioned.
Just a crowbar and a hefty grunted pull bent it back down 1/2" and stoped all the noises.
Cheers George
Wing0
Dec 13, 2013 02:39 PM
HP Sauce
Mar 7, 2009 07:49 PM
markjenross
Nov 7, 2007 07:59 PM
sas80
Nov 1, 2007 06:07 PM
russj1975
Sep 3, 2007 03:41 PM
