pulling away clunk
Old Sep 3, 2007 | 02:40 PM
russj1975's Avatar
Default pulling away clunk
I have just acquired a 99 V40 2.0 auto. I have noticed that there is a clunk when i pull away from lights or accelerate suddenly from walking speed, but which dissapears after about 20 minutes or so. The fact that is dissapears is strange. I have read lots about engine mounts and control arm bushes etc. Has anyone else had a similar problem? I believe I can replicate the clunk if with the engine running and foot on the brake, i move from R into neutral. This clunk happens along with the rocking of the car as the drive is released. I might be wrong but it sounds like the same noise. I am wondering if it is something to do with the drvieshaft?
thanks peeps
Old Sep 3, 2007 | 03:04 PM
Default RE: pulling away clunk
Engine mounts might be bad.
Old Sep 3, 2007 | 03:28 PM
russj1975's Avatar
i've just had a look with a helper to observe the engine movement during the shifting. The engine does move quite a bit, but being non-technical on volvo's, i'm not sure if it indicates anything or if the amount of movement is normal. when placed in reverse the engine tilts forwards, then when selecting N it jolts back and maybe this is causing the noise. The noise is much clearer iside the car than outside with the engine noise.
cheers
Old Sep 3, 2007 | 03:41 PM
That could very well be the noise you hear.
oliver1708
1998-2000 model year V70
Feb 11, 2013 02:07 AM
Dads850
Nov 1, 2011 03:02 PM
HP Sauce
Mar 7, 2009 07:49 PM
markjenross
Nov 15, 2007 03:33 AM
sas80
Nov 1, 2007 06:07 PM
