idle problem
Old Dec 15, 2010 | 11:15 PM
dragunov's Avatar
Default idle problem
2002 v40 1.9t starts and idles first thing in the morning fine. put it in drive with foot on the brake dies out. only restarts with foot on the pedal. after that if your not on the gas it stalls. p0102 p0107 mass air and map. cleared codes. changed fuel filter. cleaned mass air. cleaned idle air control. pulled intercooler hose checked for leaks. tried starting with mass air unplugged then map unplugged then both unplugged no different. after clearing codes maf is the first to kick on check engine light 10 times in a row. i got this car for free and the timing belt was done 3000 miles ago its in great shape and everything works. so while awaiting replies i have adjusted throttle cable to keep idle up enough so i can drive it for now. if u guys tell me to suck it up and buy a mass air i'll head to the junk yard and go grab one. thanks for your time
Old May 5, 2011 | 07:12 PM
crashspazz's Avatar
Default fuel pressure regulator
same thing as me. i tryed everything tank pump, filter,then one day on the side of the high way i decided to take it to the stealer... long story short it ended up costing me almost 300#uckS! CHECK IT MAY SAVE YO COUPLE TOO.. it mounts to fuel lail directly in frnt with a vacume hose to the intake.. good luck!!!!!!
rosesforlily
Nov 5, 2009 09:23 AM
kevmcrae
Apr 25, 2009 11:25 PM
yank50
Mar 14, 2009 11:15 AM
ss~zoso~ss
Jan 12, 2009 04:27 PM
toshields
Dec 8, 2007 04:50 PM
