Little help here! 2004 V40
Old Nov 6, 2015 | 06:24 PM
Alex G's Avatar
Question Little help here! 2004 V40
I was driving home last night and I smelled oil. It was heavy traffic so I looked around to see who was smoking. Wasn't me....... A minute later I have steam coming from under the hood. I checked the temp and it was steady in the middle where it should be. The motor runs smooth. I pull up and popped the hood. There is a geyser coming from the overflow tank which stopped shortly after I shut the motor down. Oh #$&@? There is oil in the water!
So what I know is:
It didn't overheat.
It runs as smooth as ever.
There is oil in the water.
There is no water in the oil
My guess is a spent head gasket at 150k miles.
Any other ideas? My bro suggested I might have a heat exchange oil cooler in the radiator. It doesn't look like it.
Old Nov 10, 2015 | 02:52 PM
TEEKAY's Avatar
Headgasket is probable.
The heat exchange oil cooler is on the side of the oil pan. I suppose it could have damaged plates and allowing the mix. The two hoses you see coming off of it are coolant, the oil feed is directly on the backside into the pan.
Old Nov 12, 2015 | 12:15 AM
Alex G's Avatar
Thanks for the input Teekay
I started the tear down and found another issue. I have a hairline crack in my turbo case. This is my first turbo so I don't have any experience here. The crack is in the transition from the header flange to the impeller housing. It's about 3/8" long and I never would have seen it if it wasn't starting to turn white immediately near the crack edges. Is this thing doomed? Can it be welded?
Old Nov 12, 2015 | 09:04 AM
TEEKAY's Avatar
Have a pic? My 12T had a crack -> Imgur: The most awesome images on the Internet when we replaced it with a 14T.
Old Nov 12, 2015 | 09:46 AM
Alex G's Avatar
I'll try to post one tonight
Old Nov 12, 2015 | 08:14 PM
Alex G's Avatar
Default Pic of Turbo
Here it is. What say ye?
Old Nov 13, 2015 | 08:59 AM
TEEKAY's Avatar
I'd say that's not good :/
Old Nov 14, 2015 | 01:43 PM
pierremcalpine's Avatar
Bah, I'd just leave it. It might just be a knick. Are you sure it goes all the way through?
Old Nov 14, 2015 | 09:11 PM
Alex G's Avatar
I will be extracting it tomorrow for inspection. BTW any suggestions on the best way to flush all the mud from the coolant passageways?
Old Nov 15, 2015 | 08:07 PM
Alex G's Avatar
Update
Removed turbo today. I don't know about the rest of you but I say that job is no joke! There must be some short cuts I don't know about. I found the source of the crack. The splitter on the exhaust intake side has cracks on both sides near the wall root. I guess that means I should replace it.
Question, how freely should the impeller spin?
Next question, anyone heard of oil and water mixing in the bearing block of the turbo?
Old Feb 10, 2016 | 04:52 PM
WildFish's Avatar
Default ********?
I'd flush the coolant, drive it and check it again.
Wouldn't be surprised if some numb-nuts service guy put brake fluid in the coolant overflow.
Old Mar 6, 2016 | 08:36 PM
Alex G's Avatar
Well the car is all patched up and running better then before. It runs so smooth now I end up at 80 frequently without knowing it. I'm not absolutely sure what the leak was. I have been working on bmw's for the last 30 years. So I did the oil cooler and the head gasket. Biggest pain in the **** was flushing the oil out of the coolent jacket.
Next I'm looking ta the t14 swap.....
Old Mar 6, 2016 | 08:49 PM
Alex G's Avatar
Oh ya
On top of it running so nicely. The car was throwing codes for the cat (element is actually loose and rattling in the pipe) and the coolent being under temperature. They are all staying cleared so far.
hehateme2812
Feb 7, 2014 05:03 AM
ddrewyor
Jan 8, 2012 03:36 PM
89turbo
Aug 26, 2011 02:20 AM
Garon
Apr 22, 2009 02:57 PM
shpeedy
Sep 26, 2006 08:08 PM
