problem starting up the car when the engine cold
Old Aug 11, 2015 | 01:37 PM
bksmartit's Avatar
Default problem starting up the car when the engine cold
I have 2001 Volvo V40 1.9T and I noticed when the engine is cold it takes longer to start the car but when the engine is worm I have no problem to start quickly. I am not sure what it could be but I feel like there is no fuel and it takes a 10 seconds to start the engine. I have new battery, I have fuel in the car.
Does any one know what it could be?
Thank you
Old Aug 11, 2015 | 02:23 PM
ES6T's Avatar
You need a fuel pressure regulator. There should be plenty of info around here about it.
Old Aug 12, 2015 | 12:48 PM
bksmartit's Avatar
Hey ES6T, thank you for sharing this information!
I looked on this forum about a fuel pressure regulator as you suggested and it seems this is a problem I have... I am looking forward to purchase this part and replace it.
I will post the result.
Old Aug 25, 2015 | 09:25 AM
bksmartit's Avatar
I purchased a fuel pressure regulator on eBay for $120. I installed new fuel pressure regulator on Saturday and viola! It fix my problem.
Many thanks to ES6T
Old Feb 10, 2016 | 05:03 PM
WildFish's Avatar
Default Vacuum Leaks
Check for vacuum leaks before you buy the regulator.
Had the same problem, and once the vacuum leaks were fixed it started right up.
jbasilone
Mar 15, 2014 10:59 AM
RStrohl
1998-2000 model year V70
Feb 12, 2014 12:18 PM
matt01
Jan 27, 2012 03:48 PM
seholber
Aug 19, 2011 04:48 PM
mick1275
May 4, 2007 08:17 PM
