Up arrow blinking after getting stuck in snow
Old Feb 11, 2019 | 06:18 PM
`Rocky's Avatar
Post Up arrow blinking after getting stuck in snow
I was driving home from work and right before my driveway my car got stuck and after some well timed back ups down my hill I got it in. But ever sense then this up arrow had been blinking http://imgur.com/gallery/oRzNnzf (The car is in "on" position in this pic not fully running) is there a way to turn it off ? (Volvo v40 hatchback 1.9t) it runs fine and after driving it around just now everything seems normal.
Old Feb 12, 2019 | 10:42 AM
the up arrow is used to indicate the car is in winter mode. Did you make sure the button on the console is in the correct position? Also its possible that the snow got into the wheel speed sensors or a wire was wet. Is it back to normal after a restart?
Old Feb 12, 2019 | 11:24 AM
`Rocky's Avatar
I did try restarting it and i tried disconnecting the battery for 10 minutes and its till there. i can post an update later after i drive it to work and back if that helps.
Old Feb 12, 2019 | 11:25 AM
`Rocky's Avatar
Old Feb 12, 2019 | 11:39 AM
I doubt reconnecting the battery will do anything. You may need either scan for fault codes (note not all scanners read Volvo's ABS and transmission codes) and inspect the wheels for any issues with the wheel sensor wires. You should also try playing with the transmission mode switch on the console to see if it is stuck in W mode.
Old Feb 12, 2019 | 12:36 PM
`Rocky's Avatar
I just want wanted to let you know after driving it to work the light has turned off and winter mode button is working just fine. Thankyou for the reply
Old Aug 9, 2019 | 11:54 PM
Regan Ingley's Avatar
The flashing means that the TCM has stored a fault.
Solid illumination means winter, or a lower position than drive is selected
Kimshoo1
Jul 24, 2019 10:36 AM
princessleah
Mar 7, 2011 04:53 PM
NSisavolvofan
Nov 9, 2010 04:56 PM
Silencer1
Feb 16, 2010 08:22 PM
chef
Jan 3, 2009 09:57 AM
