v40, engine electronic system light.
Old Jun 25, 2011 | 05:39 AM
woodworm's Avatar
Default v40, engine electronic system light.
Hi all,
newbie here so please forgive if I don't do things right !
I have a 1999 2.0 v40. About 8 months ago the "fault in electronic management light" came on, as everything still worked, I just ignored it (it stayed on, and still is on). My battery has now stopped charging, but I do not get "battery charge failure" light, (battery about 1 year old, so should be good).
Is it likely that I need a new alternator, or is it possible the fault lies else where?
Any help to point me in the right direction would be very welcome,
thanx :-)
Old Aug 5, 2012 | 12:12 AM
cruiser2290's Avatar
Hi Woodworm I am new to this forum,
I would like to know if you found the problem with the alternator as I have the same problem with a v40 I have recently purchased.
Old Aug 5, 2012 | 04:05 AM
woodworm's Avatar
hi cruiser, my problem turned out to be a faulty battery.
I had bought battery from halfords with a 3yr warranty, and had not used the car much in the year I had it. I took the car to halfords and they checked the battery and said it was faulty and replaced it. Everything then worked fine, although the "fault in electronic management" light still stayed on. Sorry this information probably wont be much help to you, and goodluck getting it sorted.
woodworm
Old Aug 6, 2012 | 05:37 AM
Thanks for the info. Any info is good at this point. I will look into the battery and see what happens. As for the eltronic managment light I will have to keep looking. Will let you know how I get on over the few weeks. Tanks again Cruiser2290.
Old Aug 7, 2012 | 03:44 AM
It appears the battery is ok, the voltage was low but after charging voltage was high enough to start the car. I have 2 keys for the car, one old one and one no so old. I was using the older one and when I used the not so old one the warning lights went out. The light in question was the egine imobilisation light, and with full charge and the other key all was ok. Have to look into the alternator now as it is not charging.....
Johnson.
Aug 25, 2009 10:31 PM
Garon
Apr 22, 2009 02:57 PM
manuel
Feb 18, 2009 11:00 AM
flyer1
Mar 29, 2007 01:58 PM
