V40 Misfure Mystery
Old Aug 19, 2014 | 09:12 PM
PaleST's Avatar
Default V40 Misfure Mystery
Hey all! New here - looking for some guidance.
2002 Volvo V40 1.9L Turbo
Going to cut the fat, here's what is going on:
-Started misfiring, codes P0303,304 (cyl. 3 and 4)
-Replaced all 4 plugs and both coils, still misfiring.
-Replaced all 4 injectors for good measure, still misfiring.
-Noticed fuel pump was whining a little more than it should, replaced, still misfiring.
I have swapped positions on the injectors and the misfire did not migrate with the injectors. The coils I tested in my other V40 and those are good, did the same with the spark plugs. I'm starting to come to the conclusion that it could be an issue with VVT or compression loss. Is there a base engine issue I could be overlooking? Anyone have something similar happen to them?
Any input at all would be appreciated!
edit: sorry for title spelling error
edit #2: Wires also got replaced with the new coils.
Old Aug 20, 2014 | 07:54 AM
pierremcalpine's Avatar
I'd you put Volvo spark plugs in? Apparently our vehicle is very picky about plugs. Try swapping the spark plugs first if you have not done this already.
ddrewyor
Jan 8, 2012 03:36 PM
Garon
Apr 22, 2009 02:57 PM
shpeedy
Sep 26, 2006 08:08 PM
DragonWagon
Nov 27, 2005 10:59 PM
Carbuff
Aug 18, 2005 09:06 AM
