V40 rear brakes
Old Jun 18, 2008 | 10:13 AM
tipiii's Avatar
Default V40 rear brakes
I am trying to change the rear pads and disks. The disks came off easy but I can't seem to get the pucks back into the cylinder to make room to put in the new pads. I have tried the C clamp but nothing seems to move. Do these have to be screwed in? I didn't have this problem when changed the front pads and disks six months ago?
Thanks
Old Jun 18, 2008 | 10:27 AM
tommyjumbo's Avatar
Default RE: V40 rear brakes
They are ABS brakes and yes they do have to screw back in but you should know this as you unscrewed them to take them out
Old Jun 18, 2008 | 12:29 PM
tipiii's Avatar
Sorry but I didn't unscrew to begin with them they were pushed out to begin with from the wear on the pads. And since the fronts are also ABS why did they go back with little effort and didn't require to be screwed in?
Thanks
Old Jun 18, 2008 | 01:36 PM
billofdurham's Avatar
The pistons in the front callipers do just push in but the rears have to be turned in. Volvo, of course, have a special tool.
If you look closely at the rear pistons you will see two cut-outs. These are for the special tool to fit in. It is possible to improvise to overcome the problem.
Bill.
Old Jun 18, 2008 | 03:10 PM
tipiii's Avatar
Thank you for the information. I went to the library and found a current Chilton manual that shows the special tool and while I am sure it makes turning them easy I will improvise and come up with a solution on my own.
Thanks
ddrewyor
Jan 8, 2012 03:36 PM
fingerdancer
Jun 21, 2009 07:45 AM
Garon
Apr 22, 2009 02:57 PM
shpeedy
Sep 26, 2006 08:08 PM
JimKW
Jul 4, 2005 12:19 PM
