v40 t4 engine/cooling system probs
Old Jan 15, 2009 | 11:55 AM
littlefatbudha's Avatar
Default v40 t4 engine/cooling system probs
Hi all,i am a new volvo owner,i have just aquired a volvo v40 t4 1999 from my brother inlaw.
My brother-in-law loved this car,but one day the engine revved up to about 4000rpm whilst in park and then droped again after a few seconds,and whilst driving the car seemed to pull constantly,this had never happened before,if you pulled over and stopped put into park it would high rev again then drop.Now i have it i noticed after taking around the block to try and charge battery,and while engine was still warm,turned off and the battery did not have enough power to turn over,so go out the jump leads,the engine was turning over but seem to struggle to start,while it was warm,when it did finally start it revved high(4000 rpm) for about 10 seconds then dropped again.
Now when the engine is cold the engine fan comes on after i turn the ignition on,but dont start the car,and then without starting turn ignition off the fan stays on for about 3 to 5 mins,
please help,someone told me it could be a cooling temp sensor,or engine temp sensor.Please help worried volvo owner !Steve
Old Jan 15, 2009 | 12:58 PM
Default RE: v40 t4 engine/cooling system probs
I would replace the ECT and thermostat.
Also have the battery tested.
Old Jan 15, 2009 | 01:33 PM
Many thanks.Ihave ordered a thermostat and ect,which should be here over the next couple of days,will let you know the outcome.
Old Jan 29, 2009 | 11:53 AM
Default ect & thermostat
Many thanks,changing the ect and thermostat,has stopped problems,although the idle seems to drop to low occasionally,thanks.Steve
mtkpete
North East
Apr 13, 2014 10:04 PM
mfrancis
Mar 6, 2012 11:10 PM
daz61
Jun 15, 2011 08:43 PM
Garon
Apr 22, 2009 02:57 PM
lenniefoug
Dec 4, 2005 11:30 AM
