What Spark Plugs Should I Use?
Old Jun 26, 2009 | 12:18 PM
Floaterdave's Avatar
Unhappy What Spark Plugs Should I Use?
My 2001 V40 has 75K on the clock and I want to change my plugs. I have tried 2 different sets (Bosch Platinum and NGK Platinum) with poor results. After gapping and intalling I would take the car out for a test drive. The car seems fine at lower speeds but once I get it out on the freeway and put the pedal to the floor, it starts chugging and sort of jerking. After a couple attempts at this the check engine light begins to flash. I would get my car home and reinstall my stock plugs and do the same test. No problem at all. The car would smoothly accelerate from 55 mph - 80 mph. Does the V40 1.9T need an OEM spark plug or is there a brand and type I should be using? I'm getting tired of playing the guessing game and would like to just be done with this project.
Thanks for any help,
Dave
Old Jun 26, 2009 | 07:36 PM
Get OEM plugs.
Also are the coils cracked?
What did you gap them to?
Old Jun 27, 2009 | 12:08 AM
JTDrago's Avatar
I just replaced my 01 V40 with NGK today & my car feels a little jittery compared to how it felt when I had the oem Volvo plugs. I gapped them at 0.032 as per the auto parts shop. I am going to order a new set oem plugs & the wire set from FCP. So much for cutting corners.
Old Jun 27, 2009 | 09:16 AM
Try gapping them down to about .025-.027 and see if it runs better till you get the other plugs.
.032 is to much.
Old Jun 28, 2009 | 11:04 AM
The coils don't look cracked. Is there an area of the coil I should be looking at? The plugs were gapped to .028. Who is a good source for OEM plugs?
Thanks Tech,
Dave
Old Jun 28, 2009 | 09:52 PM
FCPgroton or Dealer.
They usually crack where they go into the cylinder.
rspi
Jul 15, 2013 09:07 AM
rudy92
Jan 24, 2013 06:51 AM
docweedon
Oct 27, 2011 09:40 PM
volvoQ's
Apr 23, 2011 10:00 PM
futbolfan15
Apr 2, 2010 09:56 PM
