where is the fuel filter?
Old Aug 4, 2009 | 04:46 AM
cjhooker's Avatar
Default where is the fuel filter?
Hi All, I'm hoping someone can help, I recently drove the the car on an almost empty tank and since then the car is misfiring a little, I thought I would change the fuel filter, is this an easy job? where is the filter located?
Cheers
Chris
Old Aug 4, 2009 | 07:29 PM
If it is a 2001-2004 then it is under the drivers side by the rear tire. It is not bad at all to replace.
Old Aug 8, 2009 | 11:12 PM
ricksv40's Avatar
Default Fuel filter
I tried to change my filter and realized that there is a certain spaner wrench which is needed to remove one of the two connections
Old Aug 8, 2009 | 11:41 PM
A pair of needle hose pliers between the filter and line with a little bit of pressure will push the insert in and allow the line to be slid off.
timoc663
Aug 14, 2016 05:35 PM
inilegna
Sep 25, 2013 03:27 PM
smithnr
Apr 8, 2013 04:56 PM
CoVoVo
Oct 24, 2012 10:19 PM
AnEskimo
May 15, 2011 12:32 AM
