1.6 Edrive power loss
Old Aug 8, 2023 | 03:04 AM
Dobbythenerd's Avatar
Default 1.6 Edrive power loss
Hello everyone. Im looking for some advise about my 2010 volvo v50 1.6 edrive diesal. The car has a lack of power and does not accelerate. When we got the car originally it would drive but had a horrible judder which was resolved by replacing a faulty Injector. After replacing the injector the judder stopped but went into limp mode and code suggested a blocked DPF. We put a DPF cleaner through it and cleared the codes using a diagnostics box. The car still would not accelerate and there is no codes showing at all. We purchased the vida software and reader which also shows no codes at all. Below is a list of all the things we have done.
Turbo core replacement (It was catching slightly)
Turbo Accuator replaced
Turbo Accuator Solonoid replaced
EGR cleaned
EOYLS topped up and reset to 15/15 using the vida software
Injectors refurbished and one replaced
Mass air flow sensor replaced
Crankshaft sensor replaced
DPF sensor replaced
Boost pipes checked for leaks - No leaks
As a last resort we smashed out the internal of the DPF to see if there was a blockage causing the issue just to get the car running properly again but this does not seem to have worked either. We are about to put another DPF on the car but im not sure what else to do. We have been working on the car for 4 months and we have got nowhere. Does anyone have any ideas?
313sidney
Nov 20, 2022 04:57 AM
jackv50
Jun 30, 2022 10:58 AM
Shedhead79
Dec 27, 2021 03:45 PM
austin71
May 13, 2016 08:12 AM
dcorless
Mar 16, 2008 04:05 PM
