1.6tdi won't start
Old Oct 25, 2019 | 12:57 PM
arvalf's Avatar
Default 1.6tdi won't start
Good evening folks..!
My volvo v50 1.6tdi 2008 suddenly stopped when overtaking a car. The engine was aboute 3000rpm when it haulted.
Stopped the car and started it again without trouble, and drove on.
It happend again and again when reaching about 3-3500rpm on 2. and 3. gear.
Changed the diesel filter, but it did not help.
Red out some codes, and ut says low pressure in the rail.
Put the car away for some weeks when I was on work, and now it won't even start.
Tried to take off one and one of the 2 hoses leading in to the engine bay, to see if there was diesel pressure from the low pressure pump, but nothing..
Is the low pressure pump failing?
Can't find a hole under the rear seat for inspecting the pump, do I have to remove the dieseltank to access the low pressure pump?
Regards, arvalf
Old Nov 17, 2019 | 07:42 AM
laantonios's Avatar
Regards, arvalf
in my case (similar to yours) it was a crank sensor
Old Nov 18, 2019 | 10:17 AM
habbyguy's Avatar
If you've got no fuel pressure coming from the low-pressure pump, you've figured out where to look. Here in the US we don't have the diesel variant of the V50, so I'm betting there won't be too much help from anyone here on the specifics...
O7s60new
Sep 17, 2019 08:16 AM
richy2224
Feb 1, 2018 12:27 PM
Mick McM
Dec 30, 2016 02:26 PM
tbtx14
Nov 20, 2013 12:33 PM
smee
Penta
Nov 20, 2008 09:07 PM
