2005 V50 - Coolant in oil
Old Jan 13, 2018 | 06:35 PM
cberry's Avatar
Question 2005 V50 - Coolant in oil
Coolant in oil, no oil in coolant.
I just bought a V50 T5, with the expectation I would have to work on it. PO had bought it from a dealer, but it had started to overheat on the way home. Dealer would not take it back, since it was an As-Is purchase, and it passed emissions (CO rule - must pass emissions). A mechanic had diagnosed a bad head gasket, which made sense - overheating, missing coolant, contaminated oil, and a misfire.
It ran OK, with a misfire (passed emissions, as I said) and contaminated oil , so I bought it cheap and had it towed home.
I tore into it, replaced the head gasket, timing belt, water pump, fluid change. Long job, but expected. I couldn't find a visible issue with the old head gasket, but these things can be subtle.
However, coolant is still making it's way into the oil!
I drained the oil after a short time running, and it had significant coolant.
However, coolant system is clean - no oil in it at all, which is what I'd expect, given relative pressures.
I pulled the oil cooler from the back of the engine, and tested it with air pressure. No leak there.
Where else can coolant get into the oil?!?!?
Old Jan 13, 2018 | 09:22 PM
AutoNaut's Avatar
I have heard of issues with the oil cooler causing oil in the coolant.
Old Jan 16, 2018 | 11:51 AM
cberry's Avatar
AutoNaut:
Thanks!
I had done a test with compressed air on the oil cooler. Nothing seemed to leak between the water and oil sides. However, soon I will take the cooler out of the circuit (put a pipe between the inlet and outlet coolant hoses) and test again, with fresh oil.
ThomasK
Feb 7, 2015 07:30 AM
carson850
Jan 7, 2014 02:08 PM
no1pony
Sep 3, 2011 06:45 AM
gr8lady
Jun 4, 2009 01:29 PM
timk
Nov 16, 2007 08:33 PM
