2010 v50 Timing Belt Interval
Old Nov 28, 2011 | 03:56 PM
GadgetRick's Avatar
Default 2010 v50 Timing Belt Interval
Recently bought a used 2010 v50. High mileage (87k right now). I'm making the assumption the timing belt hasn't been changed to err on the side of caution.
What is the timing belt change interval? Can't seem to find it anywhere online.
Also, is it as much of a PITA to change the belt, tensioner, etc. as it is on most cars or is it something which someone with a little mechanical knowledge can tackle?
Thanks.
Old Nov 29, 2011 | 11:11 PM
AutoNaut's Avatar
Looks like 120K miles. The 2011 is the same.
http://esd.volvocars.com/local/us/20...nty-Manual.pdf
It is not quite as straight forward as a typical engine. Given that these cars have variable valve timing, there is a special alignment tools and procedure for setting up the belt timing.
Stan
Old Nov 30, 2011 | 06:19 AM
GadgetRick's Avatar
Stan
Thanks a bunch! Makes me feel a little better. Doesn't sound like I can tackle it myself so just have to save my pennies for when I hit $120k.
I appreciate it!
Old Nov 30, 2011 | 10:36 PM
AutoNaut's Avatar
I have done timing belts on several cars before and I am sure I could figure this one out but I just assume skip the learning curve and pay the man to do it. Must be getting old I guess.
Stan
Old Dec 1, 2011 | 06:47 AM
GadgetRick's Avatar
Stan
I don't have as much patience as I used to either. I used to not mind a, "learning curve," but I'd rather not deal with one on things like this now.
Old Dec 1, 2011 | 10:46 PM
santoury's Avatar
My trusted mechanic says that the timing belt on these is $700 ish. (Dealer said $1k) Does that sound right, for a T5 ?
Old Dec 2, 2011 | 06:06 AM
GadgetRick's Avatar
Sounds about right for most cars I've priced out.
Old Dec 3, 2011 | 03:38 PM
Jaguar.lover's Avatar
At what intervals I should replace it?
Old Dec 3, 2011 | 08:47 PM
GadgetRick's Avatar
Check the link posted in reply to my original question. Looks like 120k miles.
mt6127
Oct 28, 2025 09:33 AM
2012
Feb 9, 2014 08:26 AM
ScottyJ
Nov 9, 2012 08:18 PM
537playing
Jun 8, 2011 05:47 PM
saved_one
May 8, 2008 06:47 PM
