Help finding trailing arm
Old Nov 30, 2021 | 01:52 PM
grizli's Avatar
Default Help finding trailing arm
Hi everyone,
Can someone please point where I can source a trailing arm for 2005 V50 T5?
I found bunch compatible ones from similar P1 models, even ordered one from ebay, but they are not the same. Strut mount is different and ABS sensor is inside the housing, while mine is on top.
Appears very weird that none that I find online match.
Thank you.
Old Nov 30, 2021 | 03:10 PM
checking on Tasca's dealer web store I see the part numbers are 30736490 (right/passenger) and 30736491 (left/drivers). try googling on those numbers to see whether there are OEM/aftermarket suppliers. Also, why are you looking to replace the trailing arm? You should be able to replace the bushing if that's the concern for about $35 but may need a shop to extract/press in the part ( #30666821).
Old Nov 30, 2021 | 03:16 PM
grizli's Avatar
Thanks for reply.
it appears replacement is available from Sweden.
Not sure I can trust 3rd party? Do you Have recommendations?
Arm is damaged bent and bushing housing damaged.
Old Nov 30, 2021 | 03:26 PM
Genuine volvo part from a dealer webstore will run about $350. I usually worry more about the quality of the bushings over the metal/fit so for things like control arms with bushings I look for genuine volvo or their common OEM supplier brands like Febi, Lemsforder etc. See if FCP Euro or IPD USA sell OEM aftermarket - otherwise I'd look for a dealer web store.
jagtoes
Nov 6, 2019 07:45 PM
gpartida
Suspension
Jul 15, 2014 02:36 AM
Greg150
2001-2013 model year XC70
Jul 5, 2014 11:46 PM
chris charles
May 18, 2012 11:59 AM
spierce7
Jan 19, 2011 06:49 PM
