Volvo V50 2.0d 2008 Blue Smoke
Old Oct 12, 2022 | 11:56 AM
satsuii's Avatar
Exclamation Volvo V50 2.0d 2008 Blue Smoke
Hello, I have a problem with blue smoke and can't get rid of it.. If any of you guys could help me to find out whats the problem I would be really thankful. Already changed high pressure fuel pump, injectors, the car doesn't have nor dpf filter nor catalytic converter. I plugged my obd to check and it gave me 4 faults P0047 - Powertrain, P2263 - Powertrain Turbo/Super Charger boost System performance, U0301 - Network, P0380 - Powertrain Glow Plug/Heater Circuit "A". The car doens't smoke on higher rpm above 1500, it usually starts smoking when slow driving and on low rpm between 1000-1500. Also now it's driving way slower then usual. Could it be that it's a turbo problem ? Or can it be that the program of my ecu is bad ? In the past when I got rid of dpf and catalytic converter they programmed them out, but there's a chance that someone messed up the program.
Really need help on this!
Stephen Cutting
Nov 2, 2024 03:35 PM
Poshybalm
Jul 15, 2024 11:30 AM
Spyros
May 30, 2011 09:37 AM
leebae
Apr 19, 2007 04:20 PM
charlie brown
Nov 3, 2006 12:04 AM
