Volvo V50 Won't accelerate over 1200 rpm.
Old Apr 5, 2020 | 11:45 AM
Arnoldfreeman's Avatar
Unhappy Volvo V50 Won't accelerate over 1200 rpm.
After not using my volvo v50 2.0D (2006) a month, A strange probblem apperead.
it won't accelerate over 1200 rpm no matter what. I have tried to clean the throttle body and the egr, but nothing have changed. No trouble codes
I have a video
Any ideas. Solutions? Thank you!
Ps: the last time i used everything was fine.
Old Apr 6, 2020 | 01:31 PM
habbyguy's Avatar
So many people post "help me" requests without giving nearly enough info to really help them. I salute your approach to this!
You won't find too many diesel experts on this forum (and I'm certainly not one). I'm thinking that most "RPM-limiting" problems will throw and OBD code, while your car isn't doing that.
I'm wondering if it could be as simple as a problem with the throttle actuation (don't know if it's a fly-by-wire or cable-operated throttle). I know my (el cheapo!) Torque Pro app / OBD Bluetooth dongle combo will allow me to monitor throttle and accelerator pedal position(s)… maybe that fancy scan tool you're using can do the same?
Also, don't know what the fuel pressure in a Volvo diesel is supposed to be, but yours seems to be in the very low range for typical diesel vehicles. A quick check didn't show an easy way to find this info, but if the pressure is supposed to be a lot higher than yours (about 4700psi) then look for a bad pump / regulator or sensor.
Old Apr 6, 2020 | 06:43 PM
seems there's a duplicate of this post - I made similar comments including some links to the UK forum.
Old Apr 7, 2020 | 04:13 AM
Default Yes
yes. It was me
Old Apr 7, 2020 | 04:25 AM
Thank you! i will consider your suggestions
Arnoldfreeman
Apr 5, 2020 11:50 AM
wisewood
2001-2013 model year XC70
Jul 13, 2018 08:31 AM
vLoke
Jan 10, 2018 05:26 AM
vLoke
Jan 9, 2018 02:34 PM
mcyavuz
Nov 30, 2012 10:29 AM
