12V auxillary power sockets not working
Old Jul 11, 2022 | 03:09 PM
AndyH's Avatar
Default 12V auxillary power sockets not working
Hi, I have a UK 2005 V70 diesel and the 2 x 12v sockets in the passenger compartment are not working. don't know how long they have not been working. I have checked and replaced the fuse in the fusebox under the drivers side. I have checked that there is no power on either side of the fuse so I am assuming the problem lies between the battery and fusebox. Looking on the 'typical wiring diagram' in the Haynes manual it seems that there is a overload relay in the system, can anyone tell me where this relay is located- it is connected to the ignition switch and powered from the battery via the engine bay fusebox. Any help and advice would be greatly appreciated.
Old Jul 11, 2022 | 04:22 PM
Did you replace fuse #11 on the CEM?
Old Jul 12, 2022 | 05:30 AM
AndyH's Avatar
Thanks Hoonk - Yes- fuse changed and tested - like i said in original post there is no power to either side of the fuse. All other equipment on this fusebox is working
Old Jul 12, 2022 | 04:58 PM
The wiring diagram for a 2005 (post above) does not show a relay - there may be one built into the newer style CEM - but it would be soldered on - and Volvo does not show what's inside the later CEM.
A 2002 v70 with the earlier CEM does have an external relay that powers fuses 11-14 in the c fusebox (on the end of the dash, 13 is for the lighters) Here's a diagram of where the power relay 2/30 is on that older CEM.
For the 2005 have you scanned the cem for trouble codes and erased them?
Dirtweed
Feb 8, 2017 06:14 AM
usadventureracing
Volvo C30
Oct 14, 2015 06:38 AM
trooperone
Jun 14, 2015 10:08 AM
mewtmath
Jun 6, 2013 05:13 PM
southbaltimorevolvo
Jun 19, 2006 09:25 PM
