1998 V70 GLT Suspension
Old Jan 29, 2012 | 10:04 AM
MarkInTexas's Avatar
Default 1998 V70 GLT Suspension
Hi All,
I'm the proud owner of a new (to me) 1998 V70 GLT. It needs a new suspension, and I've read that OEM is the way to go. I see several kits available, some include just the struts, others include the mounts, seats, etc. Here is a link I found that lists several kits, though I'm open to suggestions on suppliers : 1998 Volvo V70 Suspension | FCPEuro
Should I get the "Comprehensive kit" for $411.55? It looks like it includes the struts themselves and some other bushings and rubber parts that could likely go bad. I understand this isn't a fun job, so I'd rather replace everything that may need it while I've got it apart. That said, I'm not made of money and don't want to replace things that will likely last until I replace everything again.
Any advice?
Mark
Old Jan 29, 2012 | 10:18 AM
JRL's Avatar
JRL
Whatever you do make sure you buy OEM VOLVO XC90 spring seats or IPD HD spring seats, all the others will fail prematurely
Same for the strut bearing plates.
If you choose to replace those the same applies... OEM VOLVO only
You do not want to do this job twice in 10K miles!
Shocks and struts are your choice. If you want the same ride use OEM Sachs
Old Jan 29, 2012 | 10:57 AM
Thanks for the reply JRL. I'll probably go with all-OEM then. It's a family wagon and I'm more picky about everything fitting and lasting than I am about tweaking the ride.
Do you think it's worth getting a comprehensive kit, replacing everything? I want to change anything that would likely go in the next 50k (or more) while I've got it all apart.
matt01
May 15, 2011 07:58 AM
gentlejax2
Apr 15, 2011 10:21 AM
Beau98
Jul 4, 2010 08:28 PM
1999 V70 GLT Benj
Mar 16, 2010 12:14 PM
DaveV70
Apr 23, 2007 09:27 AM
