1998 V70 Wheels - Looking to Upgrade
Greets all! Just bought a '98 V70 GLT, which I already love. Quite a change from the '78 240 I grew up with.
I'd like to swap out the standard 15" rims - and had planned on going to a 17" X 7.5" Canisto rims - however someone just warned me today how soft the rims are, and prone to bending. And that the ride would become MUCH more stiff.
Can anyone confirm this? Should I avoid going to 17" altogether?
If this is the case - does anyone have knowledge of Canisto wheels coming in 16"? I've tried to find them, but doesn't seem they exist.
Finally - if the 17"s are ok - could I hear a few tire options from users out there? I was looking at a P215/R40 17. Does this make sense? I'm trying to find a blend of performance, looks and ride.
Any thoughts would be appreciated!
-Ben
-Ben
17" wheels will work just fine on your GLT. If you go with 17x7 or 17x7.5 rims then you're probably best off with 215 or 225/45 - 17 rubber. Anything wider and you'll probably end up rubbing in lock to lock turns or the rears may contact the wells in the rear if you have a load or passengers in the rear seat and go over a significant bump, pot hole, etc. I'd suggest looking in the Swedespeed wheel and tire classifieds for some deals. I know that JRL has a set of refinished 17" Comets. They'd look great on your wagon.
http://forums.swedespeed.com/zerothread?id=90835
Mamedarling
04-09-2013 04:38 PM
S70driver
05-15-2006 05:02 PM
