1998 V70 XC-Creaking noises
Old Mar 20, 2006 | 02:07 PM
jcseymour's Avatar
Default 1998 V70 XC-Creaking noises
I am the proud owner of a station wagon. I didn't think I would be buying one for a while, but I really like my V70 XC and the way it drives. Before I bought the Volvo I had an independent mechanic look it over. It had a long laundry list of items (timing belt, serpentine belt, sway bar, tranmision leak, oil leak internally and externally, breaks and tires) which the dealer agreed to fix before I bought it.
The dealer did most of the repairs and ended up putting in a new turbo and replacing the turbo drain seal as well. The V70 continues to leak a minor amount of oil around the turbo and has developed a "creaking" noise as well, which is probably separately related. The creacking noise happens when I am turning and first starting to drive the car. Any ideas on any one of these issues. The wagon has 152,000 miles on it, but it runs very well.
Old Mar 20, 2006 | 09:09 PM
Default RE: 1998 V70 XC-Creaking noises
If you have the wheel turned all the way or most of the way it might be dry steering stops.
Look under the car on the front of the lower control arm. You will see a plastic block riveted on the control arm. Put some grease on it and see if it helps.
odonnebj
Jan 16, 2011 09:05 AM
HummerGuy
Jun 29, 2009 08:43 AM
bconley
Dec 18, 2006 01:20 AM
jcseymour
Mar 20, 2006 02:05 PM
snyderv70
Suspension
Jan 28, 2006 09:56 AM
