1998 V70R AWD Wiring/Other
Old Apr 4, 2006 | 03:14 PM
rmmagow's Avatar
Default 1998 V70R AWD Wiring/Other
I have been studying the wiring diagrams for my car in an effort to discover what was done to some connectors I found spliced up under the air cleaner box. A lot of the diagrams are specific to a given type of engine management system and the type of transmission in the car. How can I determine what is actually in the car? Via VIN, Chassis munber, some kind of tags on the car? The engine is a 5-cyl, turbo-blasted 2.3 L with spark plug wires and a distributor. The transmission is the automatic. The car has ABS and TRAC. What I seem to be slowly uncovering is that the V70R in 98 may have been closer to a 99 model than a 98. I find no real specific reference to a V70R anywhere in the wiring for the 98.
Reading a wiring diagram, Y/G does that mean a mostly yellow wire with a green stripe? Does Volvo use a single particular color for ground wires? My MB for example almost always use BROWN for ground.
My ABS/TRAC computer is due back this week and will be installed and tested. Hopefully this will go a long way to getting the car right.
Thanks for any and all advice.
Old Apr 4, 2006 | 11:42 PM
Default RE: 1998 V70R AWD Wiring/Other
The white sticker under the hood will tell you which engine is in there. It will say something like B5244t or something like that.
The trans should be a AW 50/40 transmission or something like that. My book doesn't get to specific.
It might also tell you on the sticker under the hood.
Old Apr 16, 2006 | 01:52 AM
rmmagow's Avatar
ABS/TRAC came back. Speedo and odo are OK now. ABS is working. No lights, I'll have to pop the dash and fix them, The odd wire splice I found was just that, a splice to replace a broken connector. Messy job that I've cleaned up a bit. I've got an expensive but well regarded indy lined up for a huge sorting out and maintenance run next week. 4 new tires go on tomorrow. Feels good on the road, not smooth, but strong and solid, I like that more than smooth. The interior is a little damaged and I would like to replace the front seats with new leather/alcantra but that can wait a bit. Bought a set of super nice rugs from e-bay, V70R even, they go in tomorrow. The A/C is nice and cold. The laundry list for the indy is long and probably expensive but I don't want to condemn the car because the prior owner neglected the thing. I paid about 6K for the car and am figuring on 2K for the additional work so for 8K or so I may have a pretty good car. The deeper I get into VADIS and the electrical diagrams, the less worried I am getting about the car. My whole rear hatch door thing busted loose today, guess this is a known issue with these cars, my next little project. Hope I can start loving this car soon. Seems an awful lot like a really beautiful girl with a drug problem though :-)
Old Apr 16, 2006 | 11:39 PM
Glad it is all coming together.
The Rear tailgate you can buy a repair kit to fix. Easy to install.
epperleyeric
Jul 25, 2012 02:39 PM
05yellowduc
Oct 21, 2011 06:56 PM
shrekthefearless
Dec 26, 2008 10:42 PM
rmmagow
Aug 8, 2006 12:25 AM
